ancient
PC Specification: Core I5 430M, MobileRadeon 5650 1GB, W7
Re: Splash PRO 1.4.0 & 1.4.1
Fri Feb 25, 2011 10:34 am
JCRUYFF wrote:
Splash Pro GPU Support for Chipset Intel G41 (Intel GMA X4500)? if not plz add support
thanks!!!
It should work fine. Do you experience any problems with Intel G41
Hi Mirillis,
I just noticed that CPU load is very high when using hardware acceleration on my Desktop PC with G41 Dual coreCeleron E1500@2200MhZ. With Motion2 activated is out of the question.
I am using latest drivers from intel.
Can you assist?
Sun Apr 10, 2011 10:31 pm
BDX wrote:
BDX wrote:Returning from sleep mode crashes Splash.
Still does this. Am I really the only one?
Hi, I chaeck few PCs and cannot repeat a crash situation but SPlash does not work correctly after returning from sleep mode.
We will try to fix this soon.
hadinba wrote:i have problem for opening a video file with this details :
i think Splash Pro still has problem for 422 files! ( format profile i mean )
Hi Splash does nto support 4:2:2 video decoding.
We plan to add this in future versions, probably from SPlash 2.0
oxygen wrote:Too bad that you don't have in plan DTS-HD/TrueHD suport... For a HD player this lack is a big drawback...
We plan to add support for BD version.
We also consider adding this as a plugin for other Splash versions.
ancient wrote:
thanks!!!
Hi Mirillis,
Can you assist?
Im not sure if I undesrtood you right, do you experience problems with Motion2 enabled or disabled, or this does not matter?
