EddiG
PC Specification: XP-Pro IntelP4,3200-N. Quadro NVS 280 SD
Re: Splash Lite crash on startup
Tue Oct 05, 2010 10:18 am
Hi, I have used Splash Lite 1.4 and later 1.5 with great success for 3-4 months but then suddenly it began to crash at startup with the Windows Error: " SplashLite.exe has encountered a problem and needs to close..." etc.
I have uninstalled it and reinstalled several times without luck. I have not installed any other software or changed my XP installation beside latest fixes from Microsoft which I install as they arrive.
Rgds
EddiG
Rangpuriya
PC Specification: Vista Home Prem SP2 Intel T6400
Wed Oct 13, 2010 3:32 pm
I want to share my experience with the contributors to this thread. I had similar problems. Splash Lite would not open any files. I just did the following thing and my problem was solved.
I ran 'splash lite clean startup' from installation folder. Then went to 'settings' menu > video and unchecked 'use hardware acceleration'. Voila! The problem is solved.
NumB
Wed Oct 13, 2010 6:48 pm
For 95% of the users that encounter this issue it's because your CPU doesn't support SSE2 instruction set. I just got it to work on my new PC which has SSE2 and it also works on my bro's notebook (also having SSE2). ;)
EddiG
Fri Oct 15, 2010 10:23 pm
I installed the new version 1.6 and that solved the program-crash problem! Now I can again enjoy watching videos in Splash Lite. Thanks for for new version you guys at Mirillis.
NumB
Fri Oct 22, 2010 8:56 pm
EddiG wrote:I installed the new version 1.6 and that solved the program-crash problem! Now I can again enjoy watching videos in Splash Lite. Thanks for for new version you guys at Mirillis.
I have to agree with EddiG on this one. For those with SSE2 and who encounter the below issue, the 1.6.0 version fixed it. Enjoy Splash for free again. :D
madalin981
PC Specification: na
Thu Nov 25, 2010 7:19 pm
I am getting the attached error when I ran Splash Player 1.6.0
I found there that installing this version it will fix this problem, but didn`t fix it for me.
The log file said this:
[SplashLog]
CP01=0x0000
CP02=0x0001
CP03=0x0002
CP04=0x0003
CP05=0x0004
My system is:
AMD Athlon XP 2500+
GeForce MX440 AGP 8X, 64 MB RAM
Windows XP SP3
Fri Dec 10, 2010 1:36 pm
EddiG, NumB: Thank you very much for your feedback!
Rangpuriya wrote:I want to share my experience with the contributors to this thread. I had similar problems. Splash Lite would not open any files. I just did the following thing and my problem was solved.
Hi, what is your graphics card model? And what is your graphics driver version?
madalin981 wrote:Hello,
My system is:
AMD Athlon XP 2500+
Windows XP SP3
Im affraid AMD Athlon XP 2500+ does not support SSE2 instructions. Splash cannot be run on CPU that does not support SSE2 instructions.
nicezoulou
PC Specification: windows 7
Tue Dec 14, 2010 12:51 pm
I love really Splash. I'm using it from very long time.
And now, since 1 month, it crash on start.
No matter i install it again.
Every time, i got this message :
Critical error during initialization
This application cannot be executed. ERRORS: 0x8009000f, 0x8009001a, 0x8009000f, 0x8009001a.
Anyone has a idea ?
Does anyone know this problem ?
My system : Toshiba Satellite P300-221
Windows 7. ATI Mobility Radeon HD 3650.
Thanks !!!
viviannaidoo
PC Specification: Intel Core 2 Duo T7200, Nvidia Go 7300
Wed Jan 05, 2011 6:55 am
This is really annoying!
My splash lite and pro does not work!
I want something done about it now!!
I've tried the splash clean start which also doesn't work
I get the following error when i try to start the program:
"Critical error during initialization"
The application cannot be executed. ERRORS: 0x8009000f, 0x8009000b, 0x8009000f, 0x8009000b,
This is unacceptable that I have to pay for a program which does not work!
Zero3K
PC Specification: Intel Core 2 Duo, GeForce 9400 GT, Win7
Contact: Yahoo Messenger AOL
Wed Jan 12, 2011 6:12 pm
I'm also having the crash on startup occurring. My processor is an Intel Core 2 Duo.
