Kirs90
PC Specification: Intel i5 4690k, AMD R9 390
Sun Apr 09, 2017 4:25 pm
Is there any way to repair those mp4? = (
JoseM
PC Specification: Beelink SER6 Ryzen 5 6600H 16GB DDR5
Sun Apr 09, 2017 11:00 pm
Same problem. The program crash when I give it to finish the recording, leaving unused the recorded. This happened with the latest update of Nvidia, I use to record the acceleration of nvidia.
In Windows gives me this report:
Code: Select all
Nombre de la aplicación con errores: NVDisplay.Container.exe, versión: 1.2.0.0, marca de tiempo: 0x58df0aaf
Nombre del módulo con errores: action_x64.dll_unloaded, versión: 2.3.0.0, marca de tiempo: 0x58c6b009
Código de excepción: 0xc0000005
Desplazamiento de errores: 0x00000000000077f0
Identificador del proceso con errores: 0xcb4
Hora de inicio de la aplicación con errores: 0x01d2b128f9885630
Ruta de acceso de la aplicación con errores: C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
Ruta de acceso del módulo con errores: action_x64.dll
Identificador del informe: 2e730e99-ecd0-4c33-9b7a-90c8004b7b04
Nombre completo del paquete con errores:
Identificador de aplicación relativa del paquete con errores:
The problems happen with all games. Already reinstall nvidia drivers and action, I did not work. I already sent the mail to the support
Policebear
PC Specification: i5 3570K GTX 980Ti Windows 10
Thu Apr 20, 2017 9:49 pm
So every time I try to record some games whether it be game capture, application/active window capture. Just about anything, doesn't matter, it seems to be that Action! just absolutely hates some games. I have been trying to record and have made attempts at recording Witcher 3 for the past... Hmm... 5 hours? It has been nothing but fail, after fail, after fail. I change settings, go through the different hardware acceleration. I don't know what the hell to do. I hit my recording hot key, run around, end the recording, and it just goes into (not responding) mode instantly. I got no clue what to do. It seems that any video it records just is instantly corrupted somehow after the capture, and Action! craps the bed while trying to save the captured content. Oh yah, also it doesn't freak out and crash if I record in AVI but I don't think there's anyone on here who can just get a 10TB drive to store those kind of freakishly massive files.
Update: Lol. I don't think I've ever been more annoyed. I just decided to try and record it in AVI format, but the recording is like sped up for some reason, faster than the actual live gampeplay was... GG.
I have personally went through every last single setting, like I said above, it doesn't work no matter the setting. Even when I put it in AVI, it's like the recording is sped up by 1.5 or something. It's so weird. How is it 2017 and y'all started this post in 2015, but still can't figure out what's causing this when you have a seven page thread STICKIED ON YOUR OWN FORUMS. Like... Bruh, for real? How? How dog? Do y'all just sit around makin omelets all day or something? For real man, if I was at my job, and the same persistent problem happened for two years under a product that I produced MY BOSS WOULD HAVE MY HEAD ON A PIKE. For real though, y'all need to fix this.
opus808
PC Specification: i76700,GTX980TI
Sat Apr 22, 2017 9:01 am
Is there any Solution for this Problem? I start a request. Until today no answer :?
Action stop working after stoping the record. Also with the newest Update 2.4.1 :!:
Mon Apr 24, 2017 6:58 am
It may be something with audio. To check if its true, go to audio settings, disable "Record system sounds" option and check if Action! still crashes.
gioman97
PC Specification: intel core i7 7700k,GTX 1080,windows 10
Mon Apr 24, 2017 7:53 am
Piotr wrote:It may be something with audio. To check if its true, go to audio settings, disable "Record system sounds" option and check if Action! still crashes.
that fuckin worked O.O !!!
Rodrigo
PC Specification: FX 8300, ati r9 270x, 8gb ram, win 10
Tue May 23, 2017 7:08 pm
no error but and now?
Wed May 24, 2017 6:01 am
Please contact with our technical support via support@mirillis.com
They will help you.
xKla
PC Specification: Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz
Thu Jun 01, 2017 4:25 am
I'm having this with both MP4 and AVI. It's worse with AVI though :(
I have attached screenshots of my settings and a dxdiag :)
Screenshots2.zip
(177.45 KiB) Downloaded 3827 times
Screenshots1.zip
(141.19 KiB) Downloaded 3875 times
DxDiag.zip
(14.39 KiB) Downloaded 4185 times
Fri Jun 02, 2017 6:14 am
xKla wrote:I'm having this with both MP4 and AVI. It's worse with AVI though :(
Try updating your Intel drivers and see if that helps
