xKla
PC Specification: Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz
Sun Jun 04, 2017 12:45 pm
I was able to force a manual update even though my computer didn't say I needed to. Action went unresponsive but stayed open longer than it did previously, as before it just shut down straight away and reopened again with a corrupted file.
johan
PC Specification: windows 10, i7-6700k, radeon r9 fury x
Fri Sep 08, 2017 1:08 am
Action! crash upon ending the recording process whit mp4 works fine with avi or if i unchecked record system sounds
Action video recording settings
game and application or active capture
mp4
amd app on or off
original
30 fps
duration 20 min
quality normal
bitrate mp4 100%
input range 0-255 full
use multicore recording
record mouse cursor
visualize mouse cllicks not checked
force 30bpp desktop recording not checked
Action audio settings:
microphone not checked on always record
output wav or mp4
allow multi-channel audio recording
record silence
record system sound
adio device system default
aac defalt
mic setings to default
no usb audio devices
Fri Sep 08, 2017 5:37 am
Do you use Nahimic software or Asus Sonic Suite?
johan
Sat Sep 16, 2017 9:45 am
Piotr wrote:Do you use Nahimic software or Asus Sonic Suite?
yes i have Asus Sonic Suite 2
cool it works now i uninstall Asus Sonic Suite 2
PaulCa
PC Specification: Windows 10; MSI GTX 1070; I-7 4,20Ghz
Tue Sep 19, 2017 6:15 pm
Mee too, but before it worked but since 1 week it does not work anymore, while I did not download anything!
Wed Sep 20, 2017 5:50 am
Please try removing or moving to another location all your video files from your video output folder. Once your video folder is empty please run Action! and see if it's still crashing.
sindyciaray
PC Specification: 1002, 3gb,10.1
Thu Sep 21, 2017 8:34 am
I guess i should've said desktop recording then.
Alaina15
PC Specification: Windows 8
Tue Nov 14, 2017 10:21 am
great
Robert01
PC Specification: windows 7
Tue Nov 28, 2017 8:05 pm
it implies anything, windows STILL prompts me to refresh Action! Indeed, even after as of now reinstalling it and such, which persuades that it won't not be completely refreshing in any event to the point that windows itself can perceive the refresh.
sanantonioglamour
PC Specification: asus
Tue Mar 13, 2018 7:26 am
I think so right .
Last edited by sanantonioglamour on Fri May 18, 2018 9:09 am, edited 1 time in total.
