Joco1114
Re: Splash PRO 1.2.1 & 1.2.2 & 1.2.3
Fri Oct 08, 2010 6:50 pm
Ghost wrote:Hehe, this is a HD camcorder interactive menu background.
If you plugin avchd camcorder to your pc than you can browse clips using thumbnails.
http://mirillis.com/gfx/splash_pro/spla ... r_menu.jpg
Ah, I dont have camcorder. But now it's clear. :)
Home Theater:
Synology NAS 1010+ | 9TB HDD
Re: Splash PRO 1.2.1, 1.2.2, 1.2.3 & 1.2.4
Fri Oct 08, 2010 6:54 pm
Splash PRO 1.2.4 with some small improvements is now available!
Changes:
* Subtitles support improvements:
- Font Type option added
- Font Color option added
- more font sizes available
* Multi S/PDIF and HDMI audio output support added
* Multi-display improvements
* HD Camcorder interactive menu improvements
* Small GUI improvements
Joco1114
Fri Oct 08, 2010 7:08 pm
Nice improvements. :)
I miss font styles (bold), but I like the [Play/Pause] button correction. The font sizes are "interesting". :)
I have an Asus Xonar sound card and the HDMI bitstream is still not working. SPDIF is working, but my Xonar has only HDMI output (no analog, no SPDIF). Interesting.
Thank you for your work.
Home Theater:
nunatak
Fri Oct 08, 2010 8:33 pm
I have been waiting for this, thanks.
Alexannino
PC Specification: Intel T4300, nVidia G105M, Windows 7
Fri Oct 08, 2010 10:22 pm
What about playback resume feature??
crl2007
Sat Oct 09, 2010 10:14 am
And some font position. I really hate when the writing is above the black bar. The correct position would be a row above the black bar and one on it. For 16:9 movies is not a problem, but for 2:35, 2:40 etc it is, because it takes space from the image.
Ark
PC Specification: Core2Duo , ATI 4670 , Windows 7 64
Sat Oct 09, 2010 3:53 pm
1.2.4 bug :
- Motion2 can't be enabled when hardware acceleration disable .
- Freeze after seek still happen with this file :
Code: Select all
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L5.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 16 frames
Codec ID                         : V_MPEG4/ISO/AVC
- serious judder when Motion2 enable .
- Green screen flashes sometimes
Test w/o PGS=0
Core2Duo 2Ghz , ATI 4670 512MB , Windows 7 Ultimate x64 , Catalyst 10.9
resinate
PC Specification: Win7 Ult
Sat Oct 09, 2010 7:31 pm
can u guys add support for wmv files so i can watch motion-porn XD
nunatak
Sat Oct 09, 2010 7:42 pm
Already supported.
BDX
Sat Oct 09, 2010 10:57 pm
I trialed this newest version 1.2.4. 1080p videos are completely unwatchable with GMA 4500MHD. Even some (EDIT: majority of) 720p videos are now too which makes Splash useless. Picture flickers and jumps strangely all the time. Only with a really small window it works almost normally. Can anybody confirm this?
EDIT2: It seems this behaviour was caused by Detail Boost. Disabling it makes at least 720p works ok again. Thank god.
As I have said before: Splash Lite 1.2 is still the smoothest with my setup.
