mata7
Re: Splash PRO 1.3.0, 1.3.2 & 1.3.3
Mon Dec 06, 2010 8:12 am
i really don't see a reason to pay 20.00 for this and here is why
haalispliter + ffdshow FREE
support vob sub from MKV , splash pro don't support
support DTS-MA from MKV, splash pro don't support
support PGS sub from MKV, splash pro don't support
support chapter from MKV, splash pro don't support
so i really don't see what splash pro can offer me for 20.00 when i can get more for free, and is no about the money i just don't see the point of paying for a incomplete play back software, the only thing good is the gui witch i love it
JUST MY 2 CENTS
Joco1114
Mon Dec 06, 2010 8:18 am
mata7 wrote:i really don't see a reason to pay 20.00 for this and here is why
You dont have to. But you are still here... :roll:
Home Theater:
Synology NAS 1010+ | 9TB HDD
crl2007
Mon Dec 06, 2010 6:00 pm
Subtitle positioning would have been a feature if the player actually REMEMBERED that position. If I want to watch 3-4 episodes from a tv-show I have to reposition the subtitle every time.
ancient
PC Specification: Core I5 430M, MobileRadeon 5650 1GB, W7
Mon Dec 06, 2010 9:10 pm
Greetings
The new option for capture frames to designated folder is very usefull, since I installed the Splash I cannot make any capture frames.
There is always this windows pops up "Not Available"
Any solutions or someone else expierenced the same ?
Regards
Mon Dec 06, 2010 11:21 pm
ancient wrote:Greetings
Regards
Disable Motion2. Capture frame is not available with M2 enabled.
ancient
Mon Dec 06, 2010 11:29 pm
Regards
Tahnks, that was the problem.
crl2007
Thu Dec 09, 2010 1:20 pm
crl2007 wrote:Subtitle positioning would have been a feature if the player actually REMEMBERED that position. If I want to watch 3-4 episodes from a tv-show I have to reposition the subtitle every time.
Please make this thing into a setting, not just a shortcut. Also, you did a great job with improving playback for most of the video files.
EmZvr
PC Specification: Acer TimelineX 3820TG
Re: Splash PRO 1.3.0 & 1.3.2
Thu Dec 09, 2010 4:43 pm
Ghost wrote:Joco1114: alt+f4 problem, and problem with running files with doubleclick on mltidisplay setup should be fixed now
Intel52: ctrl+o, and problem with hidden mouse cursor should be fxed now in Splash PRO 1.3.3
EmZvr, EvertonMonkey, abejan: Please try the latest 1.3.3 version. Open Playack Options panel and make sure all Basic Video Controls are set to 0. Please confirm if it works on your PCs.
Working perfectly now. Sorry for the late reply.
tuvi123
Mon Dec 13, 2010 4:35 am
Ghost:
Splash pro is my favorite player but please add this options: (past it to developers).
1) add an option to automatically load srt file that in the same directory as the movie file when playing the movie.
2) add an option to associate file types from splash pro gui settings.
3) add the option to change subtitle size by numbers (I hate this pre-defined sizes/color).
4) add a subtitle smoothing option.
JCRUYFF
PC Specification: Windows 7 Ultimate x68
Tue Dec 14, 2010 11:25 pm
plz Add more Codec Support like .rmvb thanks!!
