Code: Select all
General
Complete name : Let's Play DARKSIDERS [HD] [Deutsch] #009 Die Kreuzklinge.mp4
Format : MPEG-4
Format profile : Base Media / Version 1
Codec ID : mp41
File size : 1.47 GiB
Duration : 22mn 36s
Overall bit rate mode : Variable
Overall bit rate : 9 295 Kbps
Encoded date : UTC 2015-07-10 01:58:48
Tagged date : UTC 2015-07-10 01:58:48
Video
Format : AVC
Format profile : Baseline@L4.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=121
Muxing mode : Container profile=Baseline@3.0
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 22mn 36s
Bit rate mode : Variable
Bit rate : 9 116 Kbps
Maximum bit rate : 37.5 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 36.473 fps
Original frame rate : 60.000 fps
Minimum frame rate : 7.500 fps
Maximum frame rate : 150.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.271
Stream size : 1.44 GiB (98%)
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 22mn 36s
Bit rate mode : Constant
Bit rate : 160 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 25.9 MiB (2%)
Language : English
Tagged date : UTC 2015-07-10 01:58:48^THIS!Andarne wrote:The one thing that's pushing me away from Action!, despite my many months of usage, is the lack of multiple-audio source selection.
Looking at PlayClaw 5, which is also on Steam, the program can be configured with custom audio sources (in my case I need System, Teamspeak (headset) and Mic). Currently Action! only supports one output and one input.
I'd like the ability to add custom audio sources and, of course, save them as separate files instead as another track on the video. I don't want to have to mess around with Virtual Audio Cable just to record other sources separately.
