artpainter
PC Specification: Core2Duo E6550, Nvidia 9800GT, Win7 x86
Re: Splash PRO 1.2.1, 1.2.2, 1.2.3 & 1.2.4
Mon Oct 11, 2010 1:05 am
some bugs:
1) I do not understand whether it is feature or bug. If the sound occurs a sharp peak ( :arrow: like on image - there broken branch), then after that is muted. Recalls dynamic normalization. If the movie starts an action, then all turns into a solid dumb scene. :(
This is observed only with Splash lite and pro. On the other players is not found.
:arrow: Image
2) if in the multiplexing mkv was specified stretch like 25000/23976, then sound freeze every 3-4 second
and some feature request:
1) support for styled subtitle (ass, ssa).
2) add post effects like noise, deband etc. 12-bit LCD TV it is very necessary.
3) album art in KMPlayer - incredibly necessary thing. No longer have to navigate through countless folders with movies. On this account only dream of what will be in Splash.
:arrow:
BDX
Mon Oct 11, 2010 12:34 pm
Basic video controls don't work with HW acceleration enabled.
Joco1114
Mon Oct 11, 2010 1:51 pm
BDX wrote:Basic video controls don't work with HW acceleration enabled.
Is the Motion2 setting are "on" or "off"?
Home Theater:
Synology NAS 1010+ | 9TB HDD
joelson
PC Specification: Core i3,ati HD 5570,Windows seven ultim.
Mon Oct 11, 2010 2:28 pm
wmv not working here, version 1.2.4, :shock:
but woking in version 1.2.2 :D
nunatak
Mon Oct 11, 2010 5:57 pm
Try to open them using "drag & drop", it should work.
boldair
PC Specification: Win7 Intel core i7 8GB NVidia GT425M
Mon Oct 11, 2010 8:34 pm
hello,
since the 1.2.3 version, my computer crash when I read a ".ts" file .
where I can load the 1.2.2 and 1.2.3 version ?
thanks
boldair
BDX
Tue Oct 12, 2010 1:57 pm
No matter if it is on or off. Just noticed that even disabling HW acceleration doesn't affect.
Force video overlay works, but this brings other strange issues, e.g. red horizontal line at bottom.
Tue Oct 12, 2010 5:02 pm
If you experience problems running some file types (ie. wmv, avi, mp3) with Splash PRO using file assocciations please check the solution below.
It seems that there is some problem with Windows Installer and it adds a problematic entry to Windows registry.
We are still investigating this problem. The solution is to remove this entry, please follow one of instructions below:
1) Automatic removal with a script.
- Download a script from:
- Unzip it and run.
2) Manual removal.
- run regedit
- open HKEY_CLASSES_ROOT\Applications\SplashPro.exe\shell\open\command
- there should be only "(Default)"
- delete multistring (Type: REG_MULTI_SZ) "command" value if it exists.
nunatak
Tue Oct 12, 2010 8:21 pm
Working, thanks!
icsterm
Contact: Yahoo Messenger
Wed Oct 13, 2010 3:20 am
When pausing a movie and exiting the player, a short buzz can be heard for 0.5 seconds. Is this a known issue with 1.2.4?
