Anyway, thanks for 1.3.3 update. It's the best yet
Time bug is stll present in 1.3.3 just a minute a go seen.Splash viewer wrote:Found Time bug.
When the play automatically advances to the next file, the total playing is not reset.
File1: is 10:00
File2 is 08:00
When the player goes from 1 to 2 the total playing is still 10:00 not 08:00, its very difficult to search.
Please check latest 1.4.1 version if it still repeats.Splash viewer wrote: Time bug is stll present in 1.3.3 just a minute a go seen.
Total playing time is not reset to zero when automatically advances to the next file.
Please remove this bug....
We will check a problem with tags in srt files.Bazikcho wrote:Not missing just not read the sub tags like <i>, <b>, <u>![]()
I want that feature too or at least splash to ignore them.
Other thing on subs that I don't like is when they are long, splash make them on 3 - 4 lines. Better it will be to make them just smaller "auto adjust font size" only for long subtitle lines.
And last, one more thing that really missing me from old player is too remember position on last played files or at least last one. Playlist for last files is auto-generated in W7 taskbar when avi files are associated with Splashpro.
TY very much for this good program. Keep the good work.
