DrunkMonk74
Re: Users' Wishlist
Fri Sep 04, 2015 2:26 pm
MrSpacomo wrote:My biggest wish would be that there would be a way to record three different audio channels, i have my game, mic and teamspeak audio all set to differet outputs however i can only record two which kinda sucks
Otherwise best recording software ever! :D :D :D :D :D
^This again.
Agreed, probably the best recording software out there in terms of quality. But till the ability to record 3 audio inputs is resolved it falls behind Dxtory.
Claunator
Re: Users' Wishlist
Fri Sep 11, 2015 7:56 am
^This again.
There's something i don't get about this. Audio options are hardware related right? Like i have my headset set as my default audio source for Action, add to that my headset mic as secondary source.
So how does one set a third-party SOFTWARE (e.g. Teamspeak) as an audio source?
DrunkMonk74
Re: Users' Wishlist
Thu Sep 17, 2015 9:53 am
^This again.
You can setup virtual audio cables, (for example use Voicemeeter allows you to do this). Once you got it setup, you have your hardware input as your mic, and then game sounds in one virtual cable and TS chat in another virtual cable. You can then setup Dxtory to record those virtual cables as well as your mic into three separate audio tracks, which once you load them into your editing software you can adjust volumes individually, or remove one all together, etc.
The weird thing is, Action allows you to record virtual cables. I can do that without any problems. The issue is that it will only record TWO sources. They are very close. All they would need to do is add the ability to add a third source and you'd have an awesome piece of software. Now I'm not technical, but it seems they've done the hard part, which is allow their software to record virtual audio sources, they now just need to add the ability to add one more and then you can record your mic and TWO difference virtual audio sources, and they've got the best recording software on the market.
I'm fairly sure I've simplified the issue, but from my very non-technical view, they are so close I don't understand why they aren't implementing this!?
wasaicornel
PC Specification: windows 10 64bit
Users' Wishlist
Mon Sep 21, 2015 12:50 pm
If u make it to can use avermedia extremecap u3 capture card will be nice
GamerGuy
Re: Users' Wishlist
Fri Oct 16, 2015 6:17 pm
Could you work on lowering the CPU usage? It seems to have crept up quite a bit in the more recent versions compared to old ones. Like just doing some simple desktop recording with quicksync, the older ones would only use around 3% of the CPU and my laptop fan would hardly come on. The current version bounces between 9% and 15% and my fan never stops running at a medium rate.
Sirio
PC Specification: PCCOM Gaming Nvidia
Re: Users' Wishlist
Sat Oct 17, 2015 6:23 pm
I post my wishlist here:
http://forum.mirillis.com/viewtopic.php?f=36&t=37210
MP4 option codec.
The Emperatrix
jvmagni
PC Specification: i7 2600K, GTX 970, Windows 10
Re: Users' Wishlist
Mon Oct 19, 2015 1:16 pm
Multiple audio sources (in separated tracks). That's the only feature that I'm waiting to buy this software. I'm currently testing the trial version and using Dxtory as default one.
Hgregre
PC Specification: Xp 7.0
Re: Users' Wishlist
Thu Oct 22, 2015 2:54 am
I guess the latest update did that, because I did not have that issue when I recorded in Desktop when Mantle came out for BF4.
Noxxian
PC Specification: Windows 10 Pro, Nvidia 1070 8GB
Re: Users' Wishlist
Fri Oct 23, 2015 12:35 pm
Seperate audio channel for each source and a way to control background noise. eg, keyboard noise.
Montago
Automatic Export
Tue Nov 10, 2015 11:15 am
