Re: Splash PRO 1.2.1, 1.2.2, 1.2.3 & 1.2.4
Wed Oct 13, 2010 8:50 am
Alexannino wrote:What about playback resume feature??
crl2007 wrote:And some font position. I really hate when the writing is above the black bar. The correct position would be a row above the black bar and one on it. For 16:9 movies is not a problem, but for 2:35, 2:40 etc it is, because it takes space from the image.
Its both planned to be added in future updates.
Ark wrote:1.2.4 bug :
- Motion2 can't be enabled when hardware acceleration disable .
- Freeze after seek still happen with this file :
- serious judder when Motion2 enable .
- Green screen flashes sometimes
- What do you mean that M2 cant be enabled when h/w is disabled? What is the result of enabling it?
- About judder, does it also repeat for SD videos? What is your CPU usage when you experience judder?
- Green screen: what is the setup when it happens (motion2 on/off, h/w acceleration on/off, detailboost etc.). Does it repeat for all video codecs or only for some specific?
BDX wrote:...
EDIT2: It seems this behaviour was caused by Detail Boost. Disabling it makes at least 720p works ok again. Thank god.
As I have said before: Splash Lite 1.2 is still the smoothest with my setup.
We are going to investigate carefully Intel 4500 performance problems in coming weeks both for desktop and notebook chipsets. We will keep you informed. Detail Boost takes some graphics card resources so it is recommended to disable it when you experience performance problems.
artpainter wrote: and some feature request:
1) support for styled subtitle (ass, ssa).
2) add post effects like noise, deband etc. 12-bit LCD TV it is very necessary.
3) album art in KMPlayer - incredibly necessary thing. No longer have to navigate through countless folders with movies. On this account only dream of what will be in Splash.
Styled subtitles are planned. We also plan to add filmgrain/noise filter but this iwll be added later (cannot specif time at the moment). Album art / thumbnails browsing we plan to add when we will introduce media center like gui version, but this is planned for a further future.
joelson wrote:wmv not working here, version 1.2.4, :shock:
but woking in version 1.2.2 :D
Try the solution with registry script.
boldair wrote:...
since the 1.2.3 version, my computer crash when I read a ".ts" file .
where I can load the 1.2.2 and 1.2.3 version ? ...
Does it happen for all .ts files?
Older versions:
icsterm wrote:When pausing a movie and exiting the player, a short buzz can be heard for 0.5 seconds. Is this a known issue with 1.2.4?
It is known issue also with older versions but it seems to affect not all PCs.
It should be fixed soon.
marfpilf
PC Specification: Windows 7 x64, E8500, ATI HD 5850
Wed Oct 13, 2010 5:24 pm
Great product! Thank you.
Is there documentation anywhere on the Motion Plus2 settings? The little bit of information I've found doesn't really list all the modes. "Script aggressiveness" isn't really a good description on what is happening :).
I hear the recommended is +6
Are you guys still actively working on continuing to reduce artifacts from Motion Plus 2
Thanks again!
Wed Oct 13, 2010 7:41 pm
marfpilf wrote:Great product! Thank you.
Thanks again!
Hi and thanks for nice feedback!
There is a small info in Splash PRO User Manual but its rather short general information.
Higher Motion2 values allow for more artifacts but motion is smoother.
There are 2 modes for Motion2:
1) 2x - for values 1-5 Motion2 doubles current video framerate (24p-4p, 25p->50p, 30p->60p etc.)
2) 60p - for values 6-10 Motion2 creates 60p framerate if arifacts level is acceptable.
We keep working on next version of Motion2 and we hope to introduce quality improvements and significan performance improvements soon.
BDX
Sat Oct 16, 2010 8:58 pm
Resuming from sleep crashes Splash.
resinate
PC Specification: Win7 Ult
Sun Oct 17, 2010 12:41 am
massive sound issues with M2TS videos when u watch them on windows 7
pleasure
PC Specification: WinXP
Sun Oct 17, 2010 10:02 pm
Приветствую!
Ожидается ли в следующих версиях программы поддержка DVD? Воспроизведение с меню и прочее?..
Joco1114
Mon Oct 18, 2010 4:40 am
pleasure wrote:Приветствую!
Еще это не имеет, Mirillis работает на версию-DVD. И говорите на английском языке, пожалуйста!
(This version didnt released yet, Mirillis working on it. And please speak english.)
Смотрите на это правление:
http://mirillis.com/en/products/splashpro_features.html
Home Theater:
Synology NAS 1010+ | 9TB HDD
pleasure
Mon Oct 18, 2010 4:59 am
Joco1114 wrote:...Mirillis работает на версию-DVD. И говорите на английском языке, пожалуйста!
Thank you (Спасибо)...
nagoli
PC Specification: Phenom2 965, 4Gb DDR2, HD5830, Win7 x64
Wed Oct 20, 2010 8:11 am
Hi All,
I just tried the trial version from PRO and I must say this is a great piece of software.
I just have one issue/question to clear before I grab my payplal account :)
I have whole bunch of MKV-s with HD audio streams in the DTS-MA mostly.
I turned on the HDMI bitstream but I only got the core DTS stream and was also switching on and off contentiously.
It was working ok with the normal DTS and DD streams though.
Now seem I have more issues with playing these steams from my PC then the extra quality they provide it would be enough for me if I would get just the core stream working ok.
I have all the latest drivers. Catalyst 10.9 and Realtek HDMI driver.
Thanks for the answer in advance.
Joco1114
Wed Oct 20, 2010 9:34 am
What is the length of your HDMI cable and what is its quality? Maybe this "information burst" is too much for this cable...?
Home Theater:
