Silent Rain
PC Specification: Windows 7 Home Premium x64 (SP1)
Serious bugs in the Splash PRO!
Fri Apr 01, 2011 6:13 pm
I have NVIDIA GeForce 8600 GT. It does not support DXVA for VC1, but Splash PRO has an icon "GPU".
plus
In this video ("I Am Legend") there are artifacts (with or without DXVA):
In MPC-HC all works fine:
MediaInfo:
Code: Select all
General
Unique ID                        : 227488265116940547352758579124370080521 (0xAB24A56BF4F87099AEF0FA632F7B0309)
Complete name                    : E:\I Am Legend.mkv
Format                           : Matroska
File size                        : 13.5 GiB
Duration                         : 1h 40mn
Overall bit rate                 : 19.2 Mbps
Encoded date                     : UTC 2008-03-06 16:39:04
Writing application              : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
Video
Format                           : VC-1
Codec ID                         : WVC1
Codec ID/Hint                    : Microsoft
Duration                         : 1h 40mn
Bit rate                         : 15.8 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate mode                  : Constant
Frame rate                       : 23.976 fps
Bit depth                        :  bit0
Compression mode                 : Lossy
Bits/(Pixel*Frame)               : 0.317
Stream size                      : 11.1 GiB (82%)
Language                         : English
Audio #1
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 1h 40mn
Bit rate mode                    : Constant
Bit rate                         : 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 24 bits
Stream size                      : 1.06 GiB (8%)
Title                            : DTS 5.1 by MIF
Language                         : English
Audio #2
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 1h 40mn
Bit depth                        : 24 bits
Language                         : Russian
Re: Serious bugs in the Splash PRO!
Sun Apr 10, 2011 10:45 pm
Splash PRO supports dxva for VC-1 with GF8600.
Please check that cpu usage is lower with hardware acceleation enabled.
It is not full acceleration but cpu usage should be lower.
Silent Rain
Sun Apr 10, 2011 11:09 pm
Ghost wrote:Splash PRO supports dxva for VC-1 with GF8600.
Ok, and how about the artifacts in the movie "I Am Legend"? :roll:
Tue Apr 12, 2011 9:56 pm
We try to investigate this.
