xikar
PC Specification: 7-64 Bit Dual GTX 460 Phenom II X4 970
MKV audio problem
Fri Apr 01, 2011 7:37 pm
Well its not so much a problem as it is an inconvenience. Is there any way for me to set the default audio to English? I watch a lot of anime and one particular set has Japanese set to audio 1.
Its vorbis audio format. So every time I video boots up I have to quickly change the audio track to english every time. Which gets annoying. So is there any fix I can use?
Re: MKV audio problem
Sun Apr 10, 2011 10:45 pm
At the moment setting preffered language for audio or subtitle track is not supported yet. We plan to add this in the future. To make this option work your tracks will need to be described properly in mkv format.
