johnson321
PC Specification: vista 64 bit, ati 4800 series gfx card,
All versions of Splash crash at start up.
Sat Apr 02, 2011 12:36 am
I recently installed Splash Pro version 1.6.0. But every time I try to start the program it crashes. I get the following error:
Critical error during initialization. This application cannot be executed. Errors: 0x8009000f, 0x8009000b,0x8009000f,0x8009000b.
I have tried all versions of splash pro, and even tried splash lite. No matter what versions I try, the program always crashes before even start up.
My Pc specs are:
Alienware Laptop
Windows Vista Ultimate X64 bit version
Ati Mobility Radeon 3870x2
Ati Graphics Driver version 11.2
Intel Core 2 Extreme CPU X9100 @ 3.06GHZ
Memory : 4GB
Realtek High Definition Audio
How can I get Splash Pro to run on my computer?
Has anyone else in this forum also experienced this same error and is there any way to fix it?
Thanks,
Re: All versions of Splash crash at start up.
Sun Apr 10, 2011 10:45 pm
Hi, this is known problem connected with Windows configuration (probably some file access problems) and we work to fix this. Please make sure to scan your PC
with antivirus software as it could be a result of some viruses.
We hope to fix this problem soon.
