reciodvd
PC Specification: C2D T9300, NVIDIA9500GT, 4GB, W7 HP
Bug audio Mkv Standard Definition - FIXED
Sun Apr 03, 2011 10:21 pm
Come following the progress of this programam long and Matroska files.
My series SD (standard definition) are in Divx or Xvid and MP3 audio and keep it in Matroska container, up to version 1.4.1.0 all goes well, but since then all subsequent version of sync audio and video version included in the 1.7.0.0.
know that, you have thought it right?
Thanks
Re: Bug audio Mkv Standard Definition
Sun Apr 10, 2011 10:46 pm
Do you experience the problem both with Motion2 enabled and disabled?
reciodvd
Sun May 01, 2011 10:00 pm
Anyway, he does on and off
reciodvd
Sun May 01, 2011 10:02 pm
...and also in Splash 1.7.1 PRO EX.
reciodvd
Mon May 09, 2011 8:58 pm
Take an example of what I mention in all Windows Media Player and to the Splash version 1.4.1.0 from perfect but this version is out of sync including Splash PRO EX 1.7.1.
Gracias
DMFVisuals
PC Specification: CPU-I7-860/8GB MB memory/GPU GTX470/W7
Mon May 16, 2011 3:12 pm
True, i have the same problem with version 1.7.1.0
Thu Jul 21, 2011 10:22 pm
It should be fixed in new versions.
