Xodus
PC Specification: i-7 250GTX win 7 x64
everything has a green tint to it
Mon Apr 04, 2011 1:07 am
all the movies that I play including AVI MKV, have a green tint to them. The People's faces are green, the walls are green, etc. I've installed win7 codecs, and I don't have a problem with any other media player. I've tried enabling and disabling all of the video settings.I would appreciate the help, thanks
Re: everything has a green tint to it
Sun Apr 10, 2011 10:46 pm
Can you provide a screenshot?
Does it look the same with hardware acceleration enabled and disabled and the same about Motion2?
