xdnbkingx
PC Specification: Intel i7 3770k, GTX 670, Windows 7 64bit
Video editing software?
Tue Apr 24, 2012 2:13 pm
Hello , i have the full version on Action! but i can't find any software that i can use to edit gameplay as all i get is a black screen... any help? Im i doing anything wrong?
I Export it High Profile and High quality? Is there correct?
Thanks
xdnbkingx
Re: Video editing software?
Tue Apr 24, 2012 6:44 pm
Anybody???? Can somebody just tell me what software they use?
twindelphine
PC Specification: Windows 7 Home Premium
Tue Apr 24, 2012 11:20 pm
xdnbkingx wrote:Anybody???? Can somebody just tell me what software they use?
Your best bet is to convert using SUPER converter, then your own video editing software will be able to read the file. :)
xdnbkingx
Wed Apr 25, 2012 7:05 pm
Do you have a link for a good one as there is ALOT lol.
twindelphine
Thu Apr 26, 2012 5:49 am
SUPER converter is probably the best free converter that is fully customizable & lots of options to choose from without any charge. It'll naturally pop up near the top of Google but here it is.
sadmaan
PC Specification: Compaq Presaria V6000, Core 2 Duo
Sun Jul 15, 2012 6:38 pm
In our San Diego video production, generally we use Jahshaka and it works too good. Have you ever used it?? You may try this once. And start with trial version.
kkmin
PC Specification: Windows 10
Mon Dec 02, 2019 1:00 pm
Try Joyoshare Video Converter. It can trim video, crop video, rotate video, add effect and so on.
blackshady
PC Specification: intel i7, gtx 850, win 10
Mon Feb 10, 2020 2:27 am
Joyoshare media cutter has quite some video editing functions and is easy to handle.
It is suitable for beginners like me. There are plenty of tutorials and FAQs listed on their sites, despite that the software itself is easy to use.
I initially bought this tool because I want to add subtitles and a watermark to a video I shot without re-encoding, and it did the job pretty well.
Tanjun Yeri
Mon Feb 01, 2021 10:13 am
If you really need a video editor, I' d like to recommend a powerful software: AceMovi.
I have used it for several times. With its main function of video editing,, it really works well.
Hope this is useful for you.
Good Luck. :D
PatrickFisher
Fri May 27, 2022 9:57 am
What app are you guys using to edit the video?
