GIORCH
PC Specification: intel 2.0 Ghz, integrated, windows xp
I CANT PLAY .mp4
Sun May 06, 2012 3:47 am
since 2 weeks ago, i can not play any mp4 videos whit splash pro ex by double clicking on them. It says "the parameter its not correct"
But if I move the icon on the program, the video starts
PLEASE, HELP ME!!
sorry my english, im learning :D
Re: I CANT PLAY .mp4
Mon May 07, 2012 2:13 pm
It's a known issues and luckily we have an easy solution to fix this.
Use attached .reg files to fix "the parameter its not correct" issue. After downloading unzip the file and double click on your version .reg (in your case Splash PRO EX .reg file). Everything should be fine by now.
SplashPROEX_regfix.zip
Splash PRO EX reg file for fixing "the parameter its not correct".
(296 Bytes) Downloaded 1781 times
SplashPRO_regfix.zip
Splash PRO reg file for fixing "the parameter its not correct".
(291 Bytes) Downloaded 1670 times
GIORCH
regrettably
Wed May 09, 2012 7:44 am
radi wrote:It's a known issues and luckily we have an easy solution to fix this.
regrettably, the issue still
after download the .reg file for my version, i doubleclicked on it, the pc asked me if i really want to put this info in the register, i said yes, reboot the pc, and the problem persist.
i´m so grateful that you answer me quickly, and i hope we can solve this situation, and help more people with my problem
GIORCH
by the by...
Wed May 09, 2012 7:58 am
this is a capture of the problem after use the .reg file
the win7 taskbar and the dock are just a mod, but i have winxp ñ.ñ
P.J
Thu May 10, 2012 6:35 am
Try to make it like this:
GIORCH
Sun May 20, 2012 7:45 am
the file still not working but...... i already fixed the problem.... in the registry editor (start > execute > regedit), in the place marked by P.J. (thanks) i´ve erased every splash´s folders (obviusly I uninstalled it before) n restarted my pc, later but before reinstall, put the windows media player like default mp4´s player (and other formats player), or another program in matroska files, and reinstall it.
Now the program works, but dont feel sad, you helped me so much, i did not have notice of that folder in registry editor, ccleaner does not clean that folder so the program lets the problem when i try to reinstall it
i hope I can help with this to the people that have this issue or another similar to this
