Thanks for explanation.orhy wrote:HI,
Driver version is 11.3 from 29.03.2011.
This is what's happening: starting to play HD .mkv, GPU indication is ON, and after 5 sec (sometimes more) PC just turns off, immediately (crashes), like there is no electricity.
Motion2 is blurred in options, like you cant do anything with it (disable).
Ghost wrote: Thanks for explanation.
The problem with Windows seems extremly strange and worrying.
We have never been reported about any similar problem.
Can you check if this problem will repeat when force video overlay is enabled in settings/video?
I undersand that with hardware acceleration disabled it does not happen?
To enable Motion2 try the following:
1) stop video playback
2) open playback options
3) enable Best Quality option
