Splash Lite 1.2
Thu Jan 14, 2010 6:48 pm
We are happy to announce that Splash Lite 1.2 is available!
IT IS RECOMMENDED TO UNINSTALL PREVIOUS SPLASH LITE VERSIONS UP TO SPLASH LITE 1.0.5 BEFORE INSTALLING SPLASH LITE 1.2
Change Log:
* Display format (aspect ratio) settings added.
* MP4 files playback startup improvements.
* Subtitles improvements.
* Hardware accelerated decoding of 1080p H.264 video streams with 16 reference frames on nVidia and Intel GPUs (Windows Vista or Windows 7 and 128MB dedicated VRAM required).
* DVB-T tuner initialization stability improvements.
* Improved hardware accelerated decoding of some H.264 videos using Intel GPUs.
* Numerous GUI improvements
http://mirillis.com/splash.html
applejack
PC Specification: Q6600, 8800GT, Win7 32bit
Re: Splash Lite 1.2
Fri Jan 15, 2010 12:05 am
wow that was pretty fast, thank you !
at last ALL my h.264 mkv's are accelerated by GPU, with no exceptions!
i'm really impressed with you guys.
your codec/player has the BEST hardware acceleration support & compatibility to date.
btw, are there any plans to release your h.264 codec as an external video decoder?
elvissteinjr
PC Specification: AMD64 2GHz, ATI Radeon HD 4670, Vista 64
Re: Splash Lite 1.2
Fri Jan 15, 2010 11:06 am
The Sub Problem is fixed, good job!
But: SplashLite seems to make the line breaks for a 4:3 aspect ratio(Screen set as 16:9 in the settings). I hope you'll fix that too.
SplashLite 1.2 crashes when I try to open a XviD encoded AVI file. I don't if it's the file, but it could be played normal in all previous versions.
Helios
Re: Splash Lite 1.2
Fri Jan 15, 2010 8:52 pm
elvissteinjr wrote: SplashLite 1.2 crashes when I try to open a XviD encoded AVI file. I don't if it's the file, but it could be played normal in all previous versions.
SplashLite is a new generation player focused on HD best quality compression standards (like H.264). For backward compatibility uses system codecs to support older lower quality standards (like Xvid). Please ensure you have installed stable Xvid codec in your system.
Please try again one of the previous SplashLite versions to determine if your avi file would be played properly on actual system codecs setup. It would be very helpful feedback.
legalnet
PC Specification: Turion 64 x2 2.1, ATI Mobility HD 3450
Re: Splash Lite 1.2
Fri Jan 15, 2010 11:39 pm
Some problems with 4:3 format video.
Don't support "wmv" format, it's not good and I can't find file associations menu. Will be it realised in new versions?
travisjames
PC Specification: Windows 7 Ultimate 32-bit
Re: Splash Lite 1.2
Sat Jan 16, 2010 7:14 am
Splash Lite 1.2 crashes quite a lot when playing MKV files. It will play like 20 minutes of the video and then "Splash Lite has stopped working..."
I have no idea what the problem is. It was not doing this with 1.1.
r00ter
PC Specification: gtx260, Qcore@3ghz, windows7x64
Re: Splash Lite 1.2
Sat Jan 16, 2010 7:47 am
that was fast.
well done.
aspect works now but i would Suggest you 4 things to implent : manual contrast, brightness, level and sharpen adjust.
because a lot of videos need an extra tweak for the look. especially 1080p videos can be improved with this filters like in ffdshow.
these little helpers wont cost to much of cpu time but can do wonderful things. i add a few compare screens to you :
left side original blueray video <-> right side brightness, contrast, unsharpen mask and level adjust
hit the screens to enlarge
if you could make it possible to use this features, that would be stunning ;)
boldair
PC Specification: Win7 Intel core i7 8GB NVidia GT425M
Re: Splash Lite 1.2
Sat Jan 16, 2010 2:10 pm
hello,
just to say that, when I open window settings options , the window is trim on the right, and I can't display the line border.
the quality is always here,
an example here:
very good work
thanks.
boldair.
Window setting splasha1.2.jpg (60.27 KiB) Viewed 58912 times
Watchman
Re: Splash Lite 1.2
Sat Jan 16, 2010 2:44 pm
travisjames wrote:Splash Lite 1.2 crashes quite a lot when playing MKV files. It will play like 20 minutes of the video and then "Splash Lite has stopped working..."
Hello travisjames,
We would greatly appreciate if you could post some more details about the problem: what is your HW configuration (gfx card/cpu), are you using hardware video acceleration, a print screen of the info panel during playback would be great, can you seek to the moment before the crash and see if it happens always at the same time. Have you done any graphics card driver update lately?
There have not been any major updates in the MKV module since Splash Lite 1.1 and unfortunately we are not able to replicate this problem in our labs.
Best regards.
applejack
Re: Splash Lite 1.2
Sat Jan 16, 2010 3:39 pm
@ r00ter,
you can do all that (& more) via nvidia control panel (contrast / brightness / dynamic range / dynamic contrast enhancement / color enhancement / edge enhancement / noise reduction, etc.)
nevertheless built-in filters in splash are always welcomed...
