juanlola
PC Specification: core i5, nvidia 9800gtx+, windows 7 x64
problem with subtitles
Mon May 14, 2012 6:39 pm
I have this problem with subtitles:
And this happen when the file .srt is like this:
Code: Select all
80
00:05:50,273 --> 00:05:52,724
Probablemente solo compró ese café.
81
00:05:52,775 --> 00:05:54,026
82
00:05:54,077 --> 00:05:58,080
¿Qué será lo siguiente
que se les ocurra?
83
00:05:58,164 --> 00:06:01,399
Todo lo que sabemos, es que a las
15:23, más de dos docenas de personas
The problem always happen when there's not text after a timeline. In this case the problem is with 81 and the program think the next timeline(82) is a subtitle.
I hope you understand and can fix this problem
Thanks
Re: problem with subtitles
Thu May 17, 2012 9:04 am
It's because 81 line is empty and Splash takes 82 line as the subtitle to 81 line. If you will add a dot to your 81 line subtitles like this:
81
82
que se les ocurra?
83
it should work fine. We will add in next update an advanced parsing method that it should ignore empty lines.
juanlola
Thu May 17, 2012 3:34 pm
Thank you, I'll hope that update 8-)
