Gallow24
PC Specification: Intel Q9550, 8GB DDR2 800, Radeon 5870
Conflict between Action! and d3d9.dll
Fri Jun 01, 2012 10:46 am
some games can use plugins using a d3d9.dll in mainfolder of the game. In combination with Action! the game crashes, without Action running in background, the game works perfect with the dll. Otherwise Action works if i delete the d3d9.dll from Mainfolder.
The games support multiple d3d9.dll´s renaming them to d3d9_2.dll, d3d9_3.dll and so on. So maybe Action should check if there is another .dll and adapt to the situation. But i don´t no how the program works and i am not a programmer... ;)
For more Details or some Test i am available.
Re: Conflict between Action! and d3d9.dll
Fri Jun 01, 2012 3:37 pm
Thanks for reporting this issue. Could send it to support@mirillis.com with issue description?
Gallow24
Sat Jun 02, 2012 12:15 am
Ok. I have send a report, so i hope that this issue will be fixed. ;)
pstyle
PC Specification: i72600k, GTX670 4GB, 16GBRAM
Wed Apr 17, 2013 1:31 pm
I would also like to register this problem.
Any game I run with d3d9.dll graphics/ effects (post-processing) running will crash when Action! is loaded.
Action!'s main competitor FRAPPs does not have this problem.
My trial period for Action! is now complete. I await further news on the resolution to this issue, at which point I would certainly buy a copy of Action!.
