Manza10
PC Specification: i7 3.4, GTX 550 Ti, Windows 7 64bits, 16
The sound is cut in half for export.
Sun Jun 03, 2012 2:59 pm
Sorry for my inglish, i'm Spanish.
I have a problem with the software Action!.
When I export a recording and I see from the "Windows Media Player" does not sound, the video is dumb. And when I go to edit it from any other software (Sony Vegas for example) the audio is right up the middle. From half the audio is lost. I'm desperate, I tried system restores and everything ...
Here you have some specs of my pc:
Intel i7 3.4GHz.
16 GB Kingston RAM.
Asus GTX550 Ti.
Asus P8H77-V
All codecs and drivers in the latest version. I really need the program, if you can help me fix the problem will be very grateful.
Re: The sound is cut in half for export.
Mon Jun 04, 2012 8:57 am
When does this issue happen? after exporting video?
Manza10
Mon Jun 04, 2012 9:16 am
While The export
Manza10
Wed Jun 06, 2012 6:43 pm
I made ​​a video to make it look more clear the problem I have.
http://youtu.be/E_va2iPULVo
hugo
PC Specification: AMD Athlon II x215;geforce 315 512 MB;w7
Sat Jun 23, 2012 10:18 pm
Yeah, I have the same problem. AND I DIDN'T CRACK THE SOFTWARE. :(
