Carpenter01
PC Specification: i5 750 @4Ghz, R9 280X @1,1Ghz, 8GB DDR3
Flash crashes when using Action!
Sun Jun 17, 2012 9:59 am
Whenever Action (1.4.0) runs, and i start a youtube video, the flash plugin crashes. I use Firefox 13.0.1, Windows 7 X64 Professional. I also noticed that sometimes the Action_x64.bin consumes 25% CPU power (One core) without any recording, or use of the software.
Edit: I forgot to mention that this problem occurs since the recent flash update. Until that, everything was fine.
MozartMan
Re: Flash crashes when using Action!
Sun Jun 17, 2012 3:59 pm
It is Adobe Flash problem. Read here:
http://forum.palemoon.org/viewtopic.php?f=1&t=922
Watchman
Sun Jun 17, 2012 4:48 pm
Very strange problem indeed. We have just verified that it happens with Flash 11.3.300.257 installed. Although it does not happen always... Refreshing a site where Flash crashes several times or going to a different site with Flash animations and back to the one that was crashing helps. Action! is currently not connecting to Firefox what makes the problem even more mysterious.
As for the Action_x64.bin problem we have noticed that is usually happens after Windows updates. Rebooting system fixes the problem.
Watchman
Sun Jun 17, 2012 9:23 pm
It seems that when the Flash player crashes on a certain site, restarting Firefox and loading the site again fixes the problem.
GodsWarrior
PC Specification: -Processeur: AMD Phenom(tm) II X4 955 P
Fri Aug 17, 2012 5:49 am
Same problem with flash 11,3,300,271 installed and Action! 1.8.0.0
o0-synapse-0o
PC Specification: Core I7 920, GTX 570, Win 7 x64
Wed Aug 22, 2012 12:52 pm
Hello, it seems the problem comes from new flash protected mode introduced in version 11.3.
When you disable it, no more plugin crash but flash securised sandbox is lost...
Wed Aug 22, 2012 3:54 pm
It's still Flash player fault but we localized what's causing this issue. Next update should fix the problem.
