epicness001
PC Specification: AMD A8-3520M APU, Radeon(tm) HD Graphics
Help with action.
Tue Jun 19, 2012 2:56 pm
Hey, I reasently downloaded Action! Which by the way is the best recorder ever!.
But in order for me to use this i need it to save it in a file I can email and/or upload to youtube. When hit export it finishes and saves. Then I exit it and open the output folder. It still shows ONLY the .fic file .
Please help. I really like this recorder and will definatly buy if this problem is fixed.
Re: Help with action.
Tue Jun 19, 2012 4:02 pm
Are you sure you are looking in the right place for your exported video? but default it's set to C:\Users\User\Videos
