lincsman
PC Specification: Windows 7 - Intel Quad 2.5Ghz - ATI HD
Splash Pro - Next file
Wed Jun 20, 2012 11:23 am
My version of Splash Pro (V 1.12.2.0) has stopped playing THE next file - whether it's loaded a single file from a folder or loading the folder - I have Automatically Open Next File ticked in Playback Settings & have tried re-installing the programme but still no luck - am I missing something? anyone any ideas? - thanks
Re: Splash Pro - Next file
Tue Jul 03, 2012 2:57 pm
Does playing next file manually work correctly?
lincsman
Thu Jul 05, 2012 9:34 am
Yeah, if I click on the NEXT button next file plays ok - but I'm sure when I first used Splash Pro just double clicking on a file in a folder it would then play the other files in that folder - but it doesn't anymore ???
Thu Jul 05, 2012 4:00 pm
Please check if you haven't selected Loop video by accident (default L hotkey). If this won't solve your problem could you send us (to support@mirillis.com) a screenshot of the folder you are trying to play?
