epicness001
PC Specification: AMD A8-3520M APU, Radeon(tm) HD Graphics
Active desktop record problem
Fri Jun 22, 2012 4:12 pm
When I select the active desktop mode option it shows in the encoding program it recording the whole screen. But when I replay the video about 1 cm of the screen is cut off on each side. Is there a way to fix this? Thanks =D
Re: Active desktop record problem
Fri Jun 22, 2012 8:45 pm
Could you provide a screenshot with this issue?
epicness001
Fri Jun 22, 2012 9:31 pm
here u go
Desktop 6-22-2012 5-26-25 PM-463.jpg (211.27 KiB) Viewed 11699 times
Sat Jun 23, 2012 10:41 am
Try recording your desktop in Original Size and see if the issue still appear.
epicness001
Sat Jun 23, 2012 3:22 pm
I think I know what the problem is. I used Windows live movie editor to edit my video. Acording to reviews it has that border problem when saving. I will use a different video editor and see if that works.
