Action! 1.5.0
Tue Jun 26, 2012 10:53 am
Action! 1.5.0 is now available.
http://www.mirillis.com/en/products/action.html
What's new in Action! 1.5.0?
* FIC decoding support added for applications supporting DirectShow decoders
* Thumbnails for FIC recordings added for Windows Explorer
* Improved Action! application closing stability
* Fixed problem with cut videos when exporting with audio disabled (Audio track set to "Disabled" in export settings)
Buffometer
Contact: ICQ
Re: Action! 1.5.0
Tue Jun 26, 2012 11:18 am
Products of Magix support directshow.
Tried with version 1.5:
http://imageshack.us/g/705/26746023.jpg/.
naxxi
PC Specification: I7 2600k, GTX680, windows seven 64bits
Re: Action! 1.5.0
Tue Jun 26, 2012 12:14 pm
does fic file works on premiere /vegas / after effect now?
StarGreen
PC Specification: Win7 x64/i7 920D/12GB RAM/GTX 670 FTW
Re: Action! 1.5.0
Tue Jun 26, 2012 12:19 pm
Try it and let us know, I'm away from my editing PC right now!
birdplane
PC Specification: win 7 gtx 570
Re: Action! 1.5.0
Tue Jun 26, 2012 2:04 pm
it doesnt work in premire pro cs6 :'(
StarGreen
Re: Action! 1.5.0
Tue Jun 26, 2012 2:26 pm
OK, still doesnt work in Premiere CS5 for me, but now upon renaming .fic to .avi, the file actually imports - however just blank with no audio (although it knows the correct fps).
naxxi
Re: Action! 1.5.0
Tue Jun 26, 2012 6:29 pm
same here still doesnt work on premiere and after effect
Vux
PC Specification: Win 7 SP1, 8gb, i5-3570k, GTX 560ti
Re: Action! 1.5.0
Tue Jun 26, 2012 8:31 pm
naxxi wrote:same here still doesnt work on premiere and after effect
So this means .fic files can't be imported yet ? :cry:
How about the exported .mp4 files ? Do they still crash premiere if you try to import them ?
naxxi
Re: Action! 1.5.0
Tue Jun 26, 2012 9:41 pm
Vux wrote: So this means .fic files can't be imported yet ? :cry:
exported mp4 doesn't cause any problem for me on after effect (i'v dont tried on premiere) but .mp4 was already encoded 1 time and after editing we have to encode it one more time so quality loss i want to open .fic file directly in edition program. i hope this option will come soon :)
Re: Action! 1.5.0
Wed Jun 27, 2012 7:43 am
Hi, thank you guys for a feedback.
Some 3rd party software still cannot import Action! recordings and we are working to fix this.
The problem seems to be with fic file format and we are working now to introduce recording to avi format which should solve all compatibility problems.
Users browsing this forum: Piotr and 10 guests
