hello i have a question about license
soon i buy a licence but in some times i use a desktop or laptop to record some games but now, can i use the same license for both pc there be will some problems with that?
thanks!
2. LICENSE, SOFTWARE USE AND DISTRIBUTION
2.2.1 Single License
You may install, activate and use only one copy of the Software on a single computer at a time.
You may not run Software on two or more computers at the same time using the same serial
number.
You must uninstall the Software before installing, activating and using it on another computer.
