daniel44
can i put both of the microphone and the systemsound on100%?
Sat Jul 07, 2012 3:09 pm
hi,
i was wondering if you could add the option that gives you the ability to record both of the system sound and the microphone sound on 100%.
you see, i cant adjust the 100% volume very well and sometimes my microphone is to weak/strong or the game is too strong/weak.
can i adjust the sound differently? (like 70% on system sound and 100% on the microphone?).
will you add this to the next versions of the software?
Re: can i put both of the microphone and the systemsound on1
Sun Jul 08, 2012 11:54 am
I provided your suggestion to our developers and they will see if they can do something about this.
daniel44
Sun Jul 08, 2012 2:43 pm
radi wrote:I provided your suggestion to our developers and they will see if they can do something about this.
really?
thank you i really appreciate it! :)
