apk
PC Specification: @signature
Exporting bug (out of sync and reduced FPS)
Thu Jul 12, 2012 2:10 pm
Steps to reproduce:
1) Record a video in 60FPS (1920x1080)
2) Open "Export file" menu
3) Set Output profile to "1080p (High Profile)", Video Quality to "High, 1920x1080"
4) Convert it (with CUDA ON)
Expected result:
Converted file should be 60FPS video with synced audio.
Actual result:
Converted file has 30FPS with non-synced audio.
Phenom II x4 @3.4GHz, 8GB RAM, Geforce GTS450 1GB
Windows 7 Ultimate 64bit
Re: Exporting bug (out of sync and reduced FPS)
Thu Jul 12, 2012 9:13 pm
Try to disable CUDA and see if the issue still appear. Also it's recommended to use Auto profile if recorded video is a desktop.
apk
Sat Jul 14, 2012 7:51 pm
radi wrote:Try to disable CUDA and see if the issue still appear. Also it's recommended to use Auto profile if recorded video is a desktop.
I recorded the game. But desktop mode has the same bug.
With CUDA OFF everything is ok. But software encoding is sloooooooow. :) And this solution still leaves a bug in program. :(
vivan
Sat Jul 14, 2012 10:08 pm
apk wrote:But software encoding is sloooooooow.
Try fast presets...
Or try x264, I think you can get 50-70 fps encoding on your cpu using --preset veryfast (with quality per bitrate still better than CUDA encode).
PS Vita, Nokia N8
