4one
PC Specification: i7 950, GTX 670, Windows 7 64-bit
Exporting Requires C Drive Space?
Mon Jul 16, 2012 3:24 am
I have observed the need for C drive space in order to export videos.
Is it normal even when my export location is not C?
Re: Exporting Requires C Drive Space?
Mon Jul 16, 2012 11:48 am
During exporting process (before the final file is saved) Action! uses temporarly space in system "temp" directory.
It is usually located on disk c:, however if you need it is possible to move it to other drive.
Kashimus
PC Specification: windows 7 ultimate x64
Fri Jul 27, 2012 7:26 am
I got this problem to.
How to move that "temp" directory to anotehr drive?
Or you colud add an option in action where you can set this pre saved "temp" folder for action, like you can set the export,screenshot,sound directory.
apk
PC Specification: @signature
Fri Jul 27, 2012 8:07 am
Kashimus wrote:I got this problem to.
I agree, this option should be available in Action! settings. I am considering to buy 30-60GB SSD for system drive, so I'm OK with system Temps on it, but not with third-party software.
Temporal solution:
1) Clean up your current Temp folders. (Use CCleaner software if you don't know where it is hidden).
2) Create a new Temp folder on any drive/disk you like. For example: D:\Temp
3) Go to Control Panel -> System -> Advanced System Settings -> ("Advanced" tab) -> Environment Variables
4) Edit "Temp" and "Tmp" variables. (according to step 2)
This will change the location of your system "Temp" folders.
Phenom II x4 @3.4GHz, 8GB RAM, Geforce GTS450 1GB
Windows 7 Ultimate 64bit
Kashimus
Fri Jul 27, 2012 8:12 am
Okay thx, you and google helpd me, one more thing what happens if this tmp folder is on a removable device?
Like an external hdd which connect to the computer via usb/esata and i remove it or forget to turn it on?
apk
Fri Jul 27, 2012 8:17 am
Kashimus wrote:Okay thx, you and google helpd me, one more thing what happens if this tmp folder is on a removable device?
You will get software and system errors every time you are trying to open/run something. So removable drives are not an option for Temp folders. ;)
Kashimus
Fri Jul 27, 2012 8:19 am
Is there a way to specify a secondary route for tmp/temp, if the firs one fails?
Will ccleaner know that my tmp/temp foulders are moved when cleaning with it?
apk
Fri Jul 27, 2012 8:29 am
Kashimus wrote:Is there a way to specify a secondary route for tmp/temp, if the firs one fails?
Nope, you can't specify a secondary "Temp" folders. :(
And CCleaner reads the information about the location of your "Temp" folders from "Environment Variables".
Kashimus
Fri Jul 27, 2012 8:45 am
Okay thx the help again
