afternoonshift
PC Specification: i7, HD5800 Series, Win7 64bit
ipod export
Wed Apr 27, 2011 5:03 am
Just downloaded the trial. Was actually looking into just a good hd player, but then i saw you can convert as well, huge plus. anyways...
ipod nano 5gen, i load up my video -> export -> select ipod nano or 5g -> video quality (tried all types).
load the video on to my ipod, and it doesn't play. I tried another program that just does ipod converting, works no problem.
any ideas?
Re: ipod export
Wed Apr 27, 2011 7:39 am
Thank you for reporting a problem.
This should be fixed in next update. We plan to release the first update with some fixes and improvements this week.
