Daveymp
PC Specification: Windows 7 Pro
No sound? .fic files
Tue Jul 17, 2012 6:12 pm
Hi all,
I know this has been done to death but having some big issues with this.
I have recordings that were done using v1.3 (I am now all up to date and running v1.6). When I export the recordings there isn't any sound and when I try and import it to After Effects CS5.5 it just crashes. Any suggestions?
Cheers
Re: No sound? .fic files
Fri Jul 20, 2012 9:56 am
After exporting your files to .mp4 try to remux your videos. Here's how you can do that:
1) Download (7MB) and install Yamb - http://www.videohelp.com/tools/YAMB
This is an easy-to-use program for fixing MP4 files so they can be accepted by AE 5.
2) Start the program, click ADD and selected your exported MP4 Action! file.
3) Click "Mux" in right bottom corner.
4) New created MP4 files should work correctly now with your AE.
The "muxing" process does not affect the video quality and usually takes few minutes.
Daveymp
Mon Jul 23, 2012 12:20 pm
Thanks for that. Will give it a wizz when I escape home out of the office.
