Mafio
PC Specification: Pentium dual core, ATI MobilHD 3400, W7,
ATI Avivo doesn't work (UVD)
Wed Jul 18, 2012 1:18 pm
Hi
I have laptop Dell studio 1535
Pentium Dual-Core 1,86
2GB RAM
ATI Radeon Mobility HD 3400
I get Splash Pro and really enjoy this program but the acceleration doesn't work for me. This option automatic set in first start but CPU use is still big 50-100%. The GPU icon not show on player when playing a movie.
Please help me fix this, I uninstall all the old codecs and install only Splash Pro and can;t get it work
I install other player used DXVA and it works but i want to use Splash with working acceleration.
Maybe UVD didnt work and i can run movies only in DXGA??
Re: ATI Avivo doesn't work (UVD)
Fri Jul 20, 2012 9:35 am
Please contact support team via support@mirillis.com for further help.
Mafio
Fri Jul 20, 2012 11:21 am
Hey
I tried other video movies and its works so i dont know why this won't work on first movie i guess all tried movies has the same codec
video type: H.264/AVC but on the first movie the GPU icon only shows up on a sec and gone
You have any hint what i need check to answer this question?
P.J
Tue Jul 24, 2012 5:25 pm
Report the file information with MediaInfo.
Mafio
Tue Jul 24, 2012 9:00 pm
pe.s01e10.seasonal.forests.1080p.x264-culthd
all the episodes from this pack i don't know why they don't start with acceleration
MKV
H.264/AVC
23.976
AC3 (5.1, 48000Hz)
vivan
Wed Jul 25, 2012 2:28 am
Are you using windows 8?
PS Vita, Nokia N8
Mafio
Wed Jul 25, 2012 6:55 am
Yes but on Win 7 is be the same... I change windows few days ago
