Splash PRO EX 1.7.1
Fri Apr 29, 2011 3:42 pm
Splash PRO EX 1.7.1 is now available!
http://mirillis.com/en/products/splashexport.html
It is strongly recommended to install this update as it contains very important improvements in video encoding quality and exporting interoperability with many devices (iPod/iPhone 3G, PSP, PS3 etc.).
Splash PRO EX 1.7.1 update details:
* Improved video encoding quality
* Fixed exporting profiles for iPod/iPhone 3G and older models
* New Facebook and Facebook HD exporting profiles for automatic export and upload videos to Facebook
* Fixed 1080i/1080p exporting profiles
* Improved support for over 4GB MP4 output files
* Information about muxing (saving file) progress added
* Minimum bitrate restrictions for HD video encoding added
* Several GUI improvements
Nielo TM
Re: Splash PRO EX 1.7.1
Sat Apr 30, 2011 4:39 pm
Excellent thanks
crl2007
Mon May 02, 2011 1:56 pm
Are there any plans to add subtitles to an encoding for PSP, mobile phone etc ?
Sun May 08, 2011 9:22 pm
This is included in our plans but it is not for the nearest future.
First we will introduce "advanced view" with multiple files processing and some more options.
crl2007
Mon May 09, 2011 7:20 am
Ok, great.
hadinba
PC Specification: Intel Core2Duo T8300 @ 2.4Ghz , Win 7
Mon May 09, 2011 10:07 pm
:roll:
can you plz tell me, when will you add 4:2:2 format profile 's support into Splash Pro?! :(
alpenvideo
PC Specification: WinXP pro2002 SP3 Penti 1.7G ATI mobX300
Mon May 16, 2011 8:19 pm
Hey to all,
I am beginner using video software. Im using a trail version of 1.7.1 and would like to buy.
Splash Pro EX is an excellent program, playing all my AVCHD videos in suoerb quality.
There are two things where I need help:
- there are no functions with playlist, all I can do is to collect/order/delete filenames,
but there is no way to play those files nor to export them
- I have several *.mts files which I would like to export into a single (!) mp4 file for upload
Is there any way to do this ? Export on a single file base is fine - but I still need to merge
Thanks
Tue Jul 19, 2011 4:39 pm
hadinba wrote::roll:
This is planned for future versions but it will not be available in the nearest versions.
There is no date defined yet for 4:2:2 support.
alpenvideo wrote:Hey to all,
Thanks
The option to export selected fiels on playlist or all playlist files will be available when we will add
batch processing and advanced exporting view. This should be available quite soon in free updates.
Exporting several files into 1 output file will be also possible with advanced exporting view.
This feature will be added later, also as a free update.
