daniel44
a pause button and a question about the sound
Fri Jul 20, 2012 11:56 pm
emm i have a question.
is that possible that you will create a record/pause button?
sometimes in my recordings i need to pause the video for a few seconds, and then record again.
this is kind of annoying to export 2 or 3 different videos just becuase i can't pause the recording and keep recording (and save everything in only 1 file that i need to export).
now for my second question:
i know that i already asked this but i want to know if you are going to add this option or not.
can you add the option to record the microphone volume and the system volume how you want?
for example to put the system volume to 60% and the microphone volume to 100%
thanks for answering!
great software
foogiPROD
PC Specification: AMD FX 8120, GTX 560 ti, 4 GBRAM, 64BITS
Re: a pause button and a question about the sound
Sat Jul 21, 2012 12:07 am
Good idea, very useful
Sun Jul 22, 2012 8:03 pm
The pause button feature has been request few times already and its status is Planned. About the sound options you can manage them in Audio Settings.
daniel44
Sun Jul 22, 2012 9:48 pm
radi wrote:The pause button feature has been request few times already and its status is Planned. About the sound options you can manage them in Audio Settings.
ok thank you for the answer :)
about the sound:
i mean that i could have the microphone volume on 100% and the system sound on 60%.
here is an example:
Uploaded with ImageShack.us
if you cant see:
http://imageshack.us/photo/my-images/85 ... sound.jpg/
