0UnknowN1
PC Specification: Intel E8400, nVidia GTX275, Windows 8
Splash Pro Windows 8 Problem
Fri Jul 27, 2012 2:28 pm
Thank you for this excellent application and player but under windows 8 it has some problems even in opening the program.
Movie qualities are very bad in windows 8.
I disabled nVidia hardware acceleration but no improvements.
I watched this movie under windows 7 and it has perfect quality but in windows 8 not.
OS: Windows 8 Release Preview Build 8400
CPU: Intel Core 2 Duo E8400 3.00GHz
Graphic Card: nVidia GTX275
Thank you.
~0UnknowN1
Styvesant
PC Specification: 3570K, 680, 8gb RAM, Windows 7 (x64)
Re: Splash Pro Windows 8 Problem
Fri Jul 27, 2012 3:14 pm
As you already know, Windows 8 is currently in its consumer preview stage and will be released late October. Splash and other Mirillis products will be optimised for Windows 8 when it comes out officially.
EDIT: http://www.mirillis.com/forum/viewtopic ... 362#p19362
I'm guessing that reply is for all Mirillis products.
Splash PRO
0UnknowN1
Sat Jul 28, 2012 10:52 am
Thanks for the reply I hope they fix it soon
mattisdada
PC Specification: i7 2700k@4.3ghz, nVidia 460 , 12TB* HDD
Thu Aug 09, 2012 3:45 am
Adding to the list of things not working in Windows 8 RTM:
- No Aero Snap
- No GPU acceleration features (Motion2,etc)
Action! Has been updated for Windows 8. But I think Mirillis have abandoned Splash totally. The last update was 21/04/2012(just added jap translations) , and the last major update was 10/11/2011 . That was in 2011!! A very long time ago!
Styvesant
Fri Aug 10, 2012 5:39 am
mattisdada wrote:Adding to the list of things not working in Windows 8 RTM:
- No Aero Snap
We'll be seeing an update soon I think - they probably just want to get Action! as stable as possible, and will probably start working on Splash BD and Splash PRO; or at least I hope so.
Splash PRO
mattisdada
Sun Aug 12, 2012 8:33 am
- No Aero Snap
I really hope so :(
juanlola
PC Specification: core i5, nvidia 9800gtx+, windows 7 x64
Sat Aug 25, 2012 4:59 am
My problem is some videos (especially wmv) are not working in windows 8, and this videos work in windows 7.
Please, fix this problem
P.J
Tue Aug 28, 2012 3:15 am
Win8? I won't use it :shock:
Styvesant
Thu Sep 27, 2012 3:43 pm
The snap feature doesn't seem to work with Splash PRO in Windows 8.
Splash PRO
VeraKeisey
PC Specification: windows xp
Mon Nov 19, 2012 9:06 am
I used win 7 for a long time, it works well, and i will not try win 8 right now.
