bilbofett
PC Specification: Intel Quad Core i7, NvidiaCuda, Win7 x64
what lossless/u​ncompresse​d codecs supported for input?
Tue May 03, 2011 6:57 pm
Hi, I am editing a video, and don't want to re-encode it using lossy compression PRIOR to importing it into Splash Pro for processing.
So far I have tried about 5 differernt lossless or uncompressed codecs, and none seem supported by Splash. I get no video playback, only audio, when playing back within Splash Pro Ex.
Do you have a list of all supported codecs? Will it be possible for me to import a lossless or uncompressed video format?
What containers are supported for this as well? My target is .AVI, but I can do wmv or mov or whatever....
please let me know, it will greatly impact whether or not I purchase Splash.
If you currently do not support ANY lossless or uncompressed codecs in any shape, container, or form, please also let me know and I would greatly encourage you to add this to a newer version of Splash as encoding, re-encoding, and then encoding yet again in splash for output causes massive quality/image/resolution loss and will result in a lower quality, blurry file, even if it gets that special touch that only Splash can provide.
Thanks in advance
vivan
Re: what lossless/u​ncompresse​d codecs supported for input?
Wed May 04, 2011 9:36 am
No one, I guess.
But you could try avc in lossless mode. But I doubt that your video editing software support it... So lossless from editor -> some tool to encode to that format -> Splash pro ex.
UPD: Splash doesn't support H.264 lossless.
Or just using huge bitrate / low quantizer.
bilbofett wrote:What containers are supported for this as well?
mp4, mkv, avi... mostly all containers.
http://mirillis.com/en/products/splashe ... tures.html
From my tests splash pro ex is better when you need speedy encoding, but don't care about quality&bitrate of the result video.
And if you want to gain best quality with lower file size/bitrate - I suggest using any x264 based tool, with placebo (or at least veryslow) preset (and encoding to High profile of course).
PS Vita, Nokia N8
Sun May 08, 2011 10:21 pm
At the moment Splash does not support loseless video support.
We plan to add support in future versions.
