petre11
PC Specification: Intel Core 2 Duo,Leadtek Nvidia 8600 GT
Audio problems.... - SOLVED
Thu May 05, 2011 5:25 pm
My config
CPU Type DualCore Intel Core 2 Duo E6420
nVIDIA GeForce 8600 GT
4 GB DDR 2
Analog Devices AD1988A @ Intel 82801HB ICH8 - High Definition Audio
Creative SB Live! 5.1 Digital
WIndows 7 64X Ultimate
Video its perfect,works great....it is the best i've ever see but sound....I dont know what's going on.On all formats i try same problem.All the time is jurky and it is a sync problem.I try with all options on/off...same problem.I even reinstall Windows,no codec packs or something else.I try with both sound cards and also disable in bios the sound on the motherboard.
Please advice
Thank you...
Re: Audio problems....
Sun May 08, 2011 10:24 pm
Doeas it also happen when playing back some standard definition or low resolution videos?
petre11
Tue May 10, 2011 4:29 am
All the time.....the only time when it was a little bit better,when i was playing a large m2ts file.
thanks
petre11
Wed May 11, 2011 6:29 pm
I know you are busy and u have a lot of things to do....but,try to keep an eye on us.
Thank you
petre11
Tue May 17, 2011 8:31 pm
Something.........anything....:)
petre11
Tue May 24, 2011 2:52 pm
Solved by my self.Imagine that!!! I was working a little bit with the CPU timings and frequencies and now the sound is working perfect.I left all that to auto in bios
Hope that could help someone.
Re: Audio problems.... - SOLVED
Thu Jul 21, 2011 10:24 pm
Thank you for feedback!
