kackeldackel
PC Specification: amd, 8800gts, win7
Action! 1.7.0 not installing
Tue Jul 31, 2012 6:49 pm
I tried to install it. I start it, it wants elevated rights, I grant them, but then it just terminates. I use Win7 64bit.
Re: Action! 1.7.0 not installing
Sun Aug 05, 2012 6:46 pm
That's odd. Could you contact our support team? (support@mirillis.com)
random.monster1981
PC Specification: Phenom II 940 BE, HD 6950, Win7X64
Thu Aug 09, 2012 2:58 am
Try right clicking the installer and select Properties.
If you see "this file came from another computer and might be blocked to help protect this computer" message on the very bottom of the properties window, there is a button just to the right of it that says "unblock"
proceed to click it to unblock the file and then re-attempt installation.
