H2Os
PC Specification: Win 7 64x
How are you supposed to update Action!?
Wed Aug 01, 2012 4:16 am
I downloaded the free trial and it seemed to work, is that how we are supposed to do it?
Re: How are you supposed to update Action!?
Wed Aug 01, 2012 11:23 am
If you have Action! installed before, you should get cloud-info box near system tray that new version is available for download. Check also if you have ticked "Check for updates" box.
H2Os
Wed Aug 01, 2012 5:16 pm
I did have the option checked, I read that there was the update. Perhaps I never gave it enough time to detect an update. Will there be an issue with the way I did it? It does still show it licensed to me.
Wed Aug 01, 2012 7:17 pm
Well, you can just download the 1.7.0 from our official webiste and install it. It will automatically uninstall previous version and install new, but I'm sure you will have to re-type your activation key again so make sure you have it under your ctrl+c so you can easily paste it into activation window.
olyteddy
PC Specification: i7 2600, Intel HD2000, W7 Ultimate
Fri Aug 03, 2012 6:13 pm
I just installed the upgrade from the download and it didn't ask for my key.
