DjPara96
PC Specification: i7 2600k , radeon 7970,windows 7 hp x64
Hardware Acceleration
Mon Aug 06, 2012 9:05 am
Hello i have an i7 2600k and a radeon 7970 now i would like to use hardware acceleration, i know amd is not supported but i have intel HD in my cpu so i would like to use intel quick sync, how can i activate it? i i try to use hardware acceleration, it is grey and i can't even click it, what can i do?
RuskiRozpierdalacz
PC Specification: q9550 gtx460 6gb W7HP 64bit
Re: Hardware Acceleration
Tue Sep 25, 2012 2:59 pm
Do you have motherboard, that support Intel graphics? For example P67 won't work. Maybe in future Mirillis will add OpenCL.
Premiere Pro, Action! user. I still believe that I can help someone on this forum.
