McNasty
PC Specification: hd5700 itnel quad 860 @ 3.40ghz
Recordering Problem!
Tue Aug 07, 2012 4:59 am
Im having some recordering issues, well.. yes and no,
I can record everything fine no lag no nothing, but when the video appears in my movies bin, and i open it up it appears like this :
http://imageshack.us/photo/my-images/80 ... blems.png/
Someone help me please, i have a WELL enough computer to record this, so dont ask me if my computer meets the minimum requirements please. i really need to fix this problem
Re: Recordering Problem!
Tue Aug 07, 2012 10:13 am
Please uninstall cracked/patched version and install official one from our website www.mirillis.com.
McNasty
Tue Aug 07, 2012 4:28 pm
uhh? cracked version?
Wed Aug 08, 2012 9:55 am
McNasty wrote:uhh? cracked version?
Yes. If you are 100% sure that you are not using cracked or patched version please contact our support team via support@mirillis.com with Transcation ID and e-mail used for purchase and they will help you.
daniel44
Sun Aug 19, 2012 7:45 am
what is that problem??
i never had it.
if u have a cracked version so but the software.
at first i was using the cracked version too but i had some problems, so i bought the software and everything is good :)
