ObserverJLin
A! 1.8.0 Perfect Video Match Not Working
Tue Aug 07, 2012 6:10 pm
I'm not sure if it's just me but when I record in normal mode it's fine but when I use Ctrl + F9 (Detect fps record) it won't record/respond.
ObserverJLin
Re: Action! 1.7.0 Perfect Video Match Not Working
Fri Aug 10, 2012 5:13 pm
Dear mirillis tech team. After installing 1.8 (genuine) Detect framerate is still not working (Ctrl+F9) and the new feature Pause/resume video recording does not work either (Shift+F9) :(
Also could you add a "close" option for Action! in the mini icon? Right now there is only an "open" option.
p.s What is Change active desktop (F8) for?
Watchman
Re: A! 1.8.0 Perfect Video Match Not Working
Sun Aug 12, 2012 9:22 am
Please try changing the default hotkeys for Detect framerate (Ctrl + F9) and pause (Shift + F9). Maybe you have some kind of hotkey conflict. The "close" option will be available in the next release.
The Change active desktop (default F8) is used in multimonitor setups to select the monitor which you want to record.
