Action! 1.8.0
Fri Aug 10, 2012 2:44 pm
New Action! 1.8.0 is now available for download:
What's new in 1.8.0 version:
* NEW FEATURE: Pause/resume for video recordings added (default hotkey Shift+F9)
* NEW FEATURE: Support for Logitech multimedia keyboards LCD displays (Logitech G13/G15/G19 etc.)
* Changed default recordings folder on Windows 8 (fixes problems with desktop video recording)
* Translations improvements (mainly French)
* Stability fixes (this version should fix problems on some PCs with closing Action!)
* Small GUI improvements
Logitech keyboards LCD displays preview videos are avialable at:
http://youtu.be/apG9-n1bDV0 (Logitech G13/G15)
http://youtu.be/nKah40igydo (Logitech G19)
vivan
Re: Action! 1.8.0
Sun Aug 12, 2012 12:04 am
I've made quick test to test color accuracy. I've opened this image in image viewer, recorder it with Action!, played it back with ActionPlayer and made this screenshot.
So there are +- 1 errors (and also a bit of banding) due to RGB <-> YUV conversion. Since your decoder returns RGB32 (so it's doing this conversion by itself) you can switch to YCoCg colorspace. It has very simple coefficients (like 1/2 and 1/4), so it's fast and the main advantage: RGB <-> YCoCg is lossless (if 4:4:4 subsampling used, but with 4:2:0 it still more accurate).
P.s. btw, there you can see chroma aliasing, that's because I'm using Intel GPU - and it uses Nearest Neighbor algorithm for chroma upsampling. Splash Pro has same problem, but only when motion2 is active oO
P.p.s. also I can't get why I get no image with not system renderers (like EVR and VMR) - like madVR (or Haali) in any player.
PS Vita, Nokia N8
Watchman
Re: Action! 1.8.0
Sun Aug 12, 2012 9:03 am
Hi vivan,
The chroma aliasing problem will only occur in Action! Player when the GPU uses nearest neighbour chroma interpolation. When playing raw Action! recordings (FICV) via the VFW decoder a more advanced chroma interpolation algorithm is used (not as advanced as GPUs hardware polyphase filtering but still gives much better results and chroma aliasing is reduced).
KuKiii9
PC Specification: Acer 7750g
Re: Action! 1.8.0
Tue Aug 14, 2012 12:16 pm
Hey... in 1.8 I see bug on recorded games... when action recorded sometimes in games i have lags (cage image) and and it is cumbersome... one time when I uptaded Action have the same problem but i don't remember in which version. Please delete this bug (this problem have too my friends when recorded games)
Best wishes.
broascadilie
PC Specification: Nvidia 9800 GT,1GB Ram,4 GB RAM,OS=7-x64
Can't see any audio file,for editing reasons
Tue Aug 14, 2012 7:03 pm
Hello Mirillish Team ! I have a big problem
First of all i just can't understand what to tick or not in audio settings,because everytime when i record games,they r recording fine but,when i load the recorded file into let's say Sony Vegas,in the TimeLine i have ONLY and ONLY 1 file with no audio.& when i press the play button for preview in Vegas,the video goes,but NO AUDIO
But the strange fact is that when i play the recorded file into BsPlayer or any video player,it goes like charm.Everything OK.
What is not working for me ? Should i change something ?
I have a VIA sound card,integrated.With Fraps i have no problem,only with Action.I dont want to give up on Action,cause it's a great app for recording,far better then Fraps but if my problem will continue,then i think i will give up on Action
And pls,pls,pls explain us those audio Options in Action,like what Record Silence means or what audio settings should we chose for games recording
Re: Action! 1.8.0
Tue Aug 14, 2012 8:52 pm
KuKiii9 wrote:Hey... in 1.8 I see bug on recorded games... when action recorded sometimes in games i have lags (cage image) and and it is cumbersome... one time when I uptaded Action have the same problem but i don't remember in which version. Please delete this bug (this problem have too my friends when recorded games)
Best wishes.
Hi, did you experience this probem with previous 1.7.0 version?
Do you experience it with all games or only with some specific titles?
Re: Can't see any audio file,for editing reasons
Tue Aug 14, 2012 9:07 pm
broascadilie wrote:Hello Mirillish Team ! I have a big problem
Please see the following topic where Watchman explains the problem:
http://www.mirillis.com/forum/viewtopic ... 36&t=14397
Please disable multichannel audio option and check if problem is solved.
We hope that Vegas will fix this problem soon.
Record silence option is dedicated to audio recording only mode.
With this option it is possible to perform audio recording even when no sound is played in Windows.
KuKiii9
Re: Action! 1.8.0
Tue Aug 14, 2012 9:46 pm
Best wishes.
Hi there. I think that all is well in version 1.7 but the other day I had cut down the image (lag) ...
I have a problem with the game GRID (it is based on direcxt 9)
I do not know what is happening. Sometimes possible to record 5 minutes without lag, but then they appear, and so cuts down every 7-10 seconds.
Please help ... (btw. when I press "record" I've got 40 fps ... I do not know why, I have good parts in the pc, and this game is from 2007) Normally i have 100-80 Fps
broascadilie
Tue Aug 14, 2012 10:55 pm
Ok i did what u told,disabled multichannel,recorded ghost recon future soldier game,but i can hear everything except character voices ! And yeah now Sony Vegas detecs the audio,but it's not audio complete !
MozartMan
Wed Aug 15, 2012 3:34 am
broascadilie wrote:Ok i did what u told,disabled multichannel,recorded ghost recon future soldier game,but i can hear everything except character voices ! And yeah now Sony Vegas detecs the audio,but it's not audio complete !
Character voices probably coming from the center channel.
Here is workaround how to get multichannel recording in Action! 1.8 and then load in Vegas with audio and video.
Download and install XviD4PSP 5 from here: http://www.videohelp.com/tools/XviD4PSP
Capture screen with Action! with multichannel enabled.
Load captured AVI file into XviD4PSP 5, select AVI as output, set video and audio to "copy", encode as new AVI file.
It does not re-encode when you set to "copy". You just get new re-muxed AVI file with original captured video and audio quality and can load it into Vegas for editing.
