MozartMan
[RESOLVED]Action! 1.8 Audio Issue with Sony Vegas
Sat Aug 11, 2012 2:15 pm
Hi Mirillis team.
With Action! 1.6 I was able to load AVI file into Vegas 10. After updating to 1.8 Vegas 10 doesn't recognize audio track in AVI file. It says: Stream attributes could not be determined.
Please, fix it.
Otherwise Action! getting better and better.
Dahnark
PC Specification: I7 3770k GTX 670 Windows 7 64Bits
Re: Action! 1.8 issue with Vegas 10
Sat Aug 11, 2012 4:57 pm
me too... .avi have audio but vegas 11 dont reconize...
MozartMan
Sat Aug 11, 2012 6:25 pm
Dahnark,
I found work around until Mirillis fixes the issue with audio track in AVI file.
I load captured AVI file into XviD4PSP 5, set video to copy, and audio to PCM re-encoding. This way I get new AVI file with original captured video quality and proper audio track and can load it into Vegas for editing.
Watchman
Sun Aug 12, 2012 9:15 am
Hi MozartMan!
Are you recording audio in multichannel mode (5.1 etc.). Unfortunately Vegas does not properly handle WAVEFORMATEXTENSIBLE audio signalled tracks in AVI :( I think it was working in the past as Action! did not use WAVEFORMATEXTENSIBLE for multichannel audio tracks... but this was not working in WMP and Windows Live! Movie Maker :( Please try to disable the "Allow multi-channel audio recording" option in Action!'s Video Recording panel. This should solve the problem with Vegas... but will only give stereo audio.
MozartMan
Sun Aug 12, 2012 1:01 pm
Thanks Watchman.
Yes, it was set to record multichannel audio under video settings. I unchecked that and Vegas recognized stereo audio track in AVI file. But as I said in my previous post I found work around for multichannel audio track. XviD4PSP 5 to the rescue!
Dahnark
Sun Aug 12, 2012 2:31 pm
MozartMan wrote:Dahnark,
but I would like that I can put .avi directly.
i probe without multichannel
Dahnark
Sun Aug 12, 2012 3:52 pm
solved, turn off multichannel ^^
broascadilie
PC Specification: Nvidia 9800 GT,1GB Ram,4 GB RAM,OS=7-x64
Re: [RESOLVED]Action! 1.8 Audio Issue with Sony Vegas
Wed Aug 15, 2012 12:17 am
I have another solution that i wood say it's much more simplier ! WITH MULTICHANNEL OPTION ENABLED !
I've made a .gif for that but i have that Option in context menu that u see and honestly speaking im not sure what program added that in my context menu,all i know is that it works.I've searched thru my installed app,couldnt find something relevant ...I think is from some codec,or something,i realy dont know
http://i.imgur.com/v7wrm.gif
MozartMan
Wed Aug 15, 2012 1:06 am
Well, I just updated my workaround. I load AVI file into XviD4PSP 5 and set both video and audio streams to "COPY" to create (remux) to new AVI file without re-encoding at all. And it loads in Vegas.
broascadilie
Wed Aug 15, 2012 3:12 pm
broascadilie wrote:I have another solution that i wood say it's much more simplier ! WITH MULTICHANNEL OPTION ENABLED !
I've made a .gif for that but i have that Option in context menu [ Extract Audio Stream ] that u see and honestly speaking im not sure what program added that in my context menu,all i know is that it works.I've searched thru my installed app,couldnt find something relevant ...I think is from some codec,or something,i realy dont know
I have found of what i was talking about ! It's about Dxtory ! I dont want to make advertising about Dxtory but when u install Dxtory,in the install folder u will find '' AudioStreamSplitter.exe '' and that litle tool ads in the context menu the '' Extract Audio Stream '' option.Dxtory it is a good tool for recording games but honestly speaking,Action it's just much better !
