Silent Rain
PC Specification: Windows 7 Home Premium x64 (SP1)
Function to change the Aspect Ratio (AR) of video
Wed May 11, 2011 1:27 am
Sometimes there are video files that have the wrong aspect ratio (AR). Therefore, need such a function. MPC-HC has this feature. This is a very important function, which is severely lacking :!: :( Please add it asap :roll:
Media Player Classic - Home Cinema (instead of a AR is 16:9, by default the AR is 4:3):
Test video: Bleeding Through - Line in the Sand.mpg
Re: Function to change the Aspect Ratio (AR) of video
Mon May 16, 2011 8:53 am
Thank you for your detailed and valuable report.
We plan to add in future versions of Splash forcing aspect ratio for both video and display.
The video is for the issue described by your, and display is for older plasma/lsd tvs that support low 4:3 resolution for PC input only.
This features are included in our plans but there is no date defined yet when will be avialable.
Silent Rain
Mon May 16, 2011 5:53 pm
Okay, we will wait :)
