xdnbkingx
PC Specification: Intel i7 3770k, GTX 670, Windows 7 64bit
Can't record on any games?
Sun Aug 12, 2012 9:28 pm
For some reason everytime i open Action! since update 1.8.0.0 it will not work, the UI on screen does not appear? and when i try and close it, it crashes? any help?
Miguel
Re: Can't record on any games?
Mon Aug 13, 2012 1:51 am
Same thing happened to me yesterday, I had to reboot to make it work again.
Don't know if it's related to my PC or Action! 1.8.0.
Watchman
Mon Aug 13, 2012 8:09 pm
Hi xdnbkingx,
Please try rebooting your system. Are you usually shutting down your PC or just putting it to sleep/hibernate?
Thanks for your feedback.
xdnbkingx
Mon Aug 13, 2012 8:53 pm
Watchman wrote:Hi xdnbkingx,
Yeah once i have rebooted it works but i shouldn't have to reboot just to use it. Other then this problem Action! is fantastic and the best video recording software around :)
daniel44
Tue Aug 14, 2012 11:04 am
i noticed that problem too.
sometimes there are a few process in the task manager of action!
every time that you open the software the task manager open's 3 process:
Action_x86.bin
Action_x64.bin
Action.exe
sometimes the computer open's this process again so you have action opened twice so you need to close the process in order to make the software work.
Owly
PC Specification: windows 7 home premium
Tue Sep 10, 2013 12:02 am
i cant record on games and application mode though? Should i reboot too?
