tuexnovia
PC Specification: i7@4.6 win7-64 670gtx x3 SSD830
Mirillis+Premiere cs6 Codecs?
Wed Aug 15, 2012 1:24 pm
PROBLEM SOLVED AT THE END OF THE POST
Hi guys I have download this amazing software that I really like and I'm thinking about to buy it quite cheap always update but well... I got two problems.
When I shut the program always crashes no idea why. (No important it works anyway quite annoying I have to change the folder and few setting all the time that I activate it.) But is not my real problem
MY REAL PROBLEM IS.
Please guys I can't edit with premiere properly, ca I use any free codecs or whatever because I've been trying to edit few gameplays and it has lag and so on, and I got cuda so I don't know if is because of the project setting (I don't think so) or because I have to install the codecs, could you help me please guys?
Good job with this software if you make it work for everyone and good it will be the next Fraps. 100% sure (Dxtory they are not professionals.)
Re: Mirillis+Premiere cs6 Codecs?
Wed Aug 15, 2012 8:09 pm
Do you use the latest 1.8.0 version?
Can you please check if after closing Action! there is any action process visible in task manager and if it uses any cpu resources?
Do you have any problem with importing recording to Premiere or Action! recording imports fine and you have problem only with editing?
tuexnovia
Wed Aug 15, 2012 8:55 pm
Ghost wrote:Do you use the latest 1.8.0 version?
The last version yes, 30 days trial.
Depends sometime it keeps Action_x64.bin 2 or tree of them and besides anther one saying Action_x64.bin*32 and I've tried to close all of them but nothing.
But that is not my problems I mean I want 100% compatibility with premiere if I can not I can't use it.
I didn't export yet, importing is OK I import Actionfileblabla.mp4
But editing I feel and I can see that is not smooth premiere doesn't work properly with it, when you press SPACE BAR it should reproduce the video perfectly and you press play, and you can see is working fine after 10,15, seconds or more or less always randomly it gets sloowwwww.... and you can hear the sound but the video it can even get frezze. SO you can see the video at 60FPS and then at 30,24,20, and keeps there on 20... Completely random.
SO I'm sure is a problem of codecs I've installed the -ficdec_dshow_beta- but it doesn't help, and I really want to know if is gonna work properly this software because is just amazing. with Cuda and the quality and you don't lose any FPS AWESOME.
Thu Aug 16, 2012 1:23 pm
Closing problem should be fixed with next update.
Do you import mp4 files (exported in Action!) to Premiere?
Please try to import raw avi recordings, it should work much better.
tuexnovia
Thu Aug 16, 2012 1:33 pm
Ghost wrote:Closing problem should be fixed with next update.
SORRY sorry they were .AVI I don't know why I said .mp4.
NOw I wanted to make a video showing what I mean and I can't record with mirillis no idea why... I got aero activate but nothing... O my god it disappear the little FPS count on top of the screen.
tuexnovia
Fri Aug 17, 2012 12:15 am
PROBLEM SOLVED:
It was because of my HDD, I'll need another HDD or put it in RAID0 or something because when I edit the video form my SSD is just PERFECT.
But Guys I can't record my desktop the FPS counter just disappear...
